I rooted with Unrevoked Forever and now need to Unroot.
I've ran the Unrevoked S-on tool so now I have S-on.
I've loaded the PC36IMG.zip from the "How to Unroot-XDA site" to the root of my SD card.
When I power up to the white HBOOT screen it goes through the following commands:
Loading....[PC36DIAG.zip]
no Image!
Loading....[PC36DIAG.nbh]
no Image or Bad Image!
Loading...[PC36IMG.zip
Once the blue status bar in the upper right corner finishes, the screen changes to:
Checking...[PC36IMG.zip]
After less then a minute it returns to the normal HBOOT screen. I'm never given the chance to answer "yes" to whether I want it to update.
I've done several wipes, battery pulls etc. I've re-downloaded the PC36IMG.zip file as well.
Suggestions?
no Image!
Suggestions?
. In any case, what is the the hboot version? Also, have you tried searching here for vibrate not working? I think there might be a fix for that.
