Root Unrooting without a working power button
nafzimo
Just last week I finally rooted my Motorola Droid (thanks for the help)! All was good until today when I woke up and the power button didn't work. It was intermittently working this afternoon, and now it does nothing.
I was ready to unroot the phone so I could take it back to Verizon when I realized that I can't get into the bootloader screen without the power button. I tried holding the D-pad up while reinstalling the battery and I also tried the camera and volume down buttons while reinstalling the battery. The battery removal and reinstall just doesn't seem to be working to put it into the bootloader screen. Any thoughts?
If I remember correctly when I used rsdlite, I held left on the Dpad (with the keyboard out as you would normally hold it in landscape) which is up if you are holding it as you would for portrait. I'm not sure if you had tried to access bootloader before and were successful with the method you described, but I remember the wording in the instructions was different than how I got it to work. Give this a try if you tried the other way.
I know there is a widget that will reboot you into the bootloader but I dont know the name of it. Im sure someone will come along that does though
Thanks for the help. I'll try Quick Boot tonight. Is there anywhere else in this process that the lack of a power button will be a problem?
Quick Boot won't put this phone into bootloader mode. It will go into recovery, but not bootloader. I'm starting to wonder if there is something else going on... maybe the power button is just a symptom. All I did when I rooted was follow the How to Root 2.1 from Windows without losing app data from the The Guide to All Things Root Related
If you rooted a week ago and NOW the power button started going out intermittently...my guess is HARDWARE failure...not software issue.
You could pull your battery then put it back in and hold up while you plug in the charger. The charger will turn it on and should get you to the bootloader. (tried it, it works)
All day yesterday, the power button worked fine. I had no problem getting into boot loader mode using Quick Boot or using the power button and D pad. I reverted back to stock while I had the chance, but the power button continues to work fine this morning.
I hope Verizon believes me when I try to return a fully functioning phone!
Oh, I had the problem with the start button in RSD Lite 4.6 being greyed out, but I changed the sdf file name to something shorter and it worked fine.
Thanks for the help and suggestions on this one!
