Help Unscheduled Alarm
warthog01
Hi
I've recently installed the Go Launcher Ex and Alarm clock plus on my htc Desire. All's well except that every afternoon at 5:15 an alarm goes off--it's not set on my Alarm Plus, so I can't get rid of it. Can it be a remnant from the htc sense stock alarm and, if so, how can I access it to delete the alarm or perhaps even use it as default--to be honest I like the format better, but I'm tired of getting buzzed when I haven't scheduled it.
Thanks
Why not go into the Sense alarm application and see what is set? If you still have a Sense ROM the app is still there, and only Sense widgets require you are using the Sense launcher, so you should still be able to use it.
there's no Sense alarm listed in my 'all' applications selection!
It's part of the Clock app, iirc. Open the HTC Clock and check there for the unwanted alarm.
In the meantime, I'll move this to the HTC Desire section in the hope that other users can shed some light on the issue. I can well imagine how irritating it is!
