k.c.cole
Velocicomb is a UOT theme based on Honeycomb. From custom recovery toggle signature verify off, and flash the .zip from the root of your SD card.
What you get:
SkyRaider Boot Animation
Custom (Sense based) Red notification and power icons
Custom Honeycomb battery indicator
-Red (#f50000)
Custom Font: Hero Light (similar to Comfortaa but thinner)
Custom window animations (Rudolph)
Custom Notification window
-Red Glass look
-Transparent red highlights
Custom Popups
-Transparent Grey
-Red (#f50000) Glow
Download Link (temp): [UOT] Velocicomb Fire
If you DL and use it, and you like it, please hit the Thanks button.
You feedback is appreciated and encouraged; but, please keep any criticism constructive
NOW AVAILABLE AS A VelocityMorph Theme!!
Download: Velocicomb Fire Theme
-To use VelocityMorph:
1. Download VelocicombFire.zip
2. Using you file manager (e.g Astro) move the .zip into the VelocityMorph folder located on your SD card.
3. Open Velocity Toolkit
4. Open the Terminal Emulator
5. Option 1
6. Option 3
7. Option 1
8. Select VelocicombFire
They do the rest!
Thanks Velocity Team for you hard work!
I was not able to get the boot animation into the VelocityMorph File, so I made a flashable file. It is essentially still a UOT file. Signature Verification must still be turned off before flashing it from recovery.
RedEyeBootanimation
Screen shots:
Wallpaper: From Velocity 1.1 Wallpapers
Icons and Launcher: ADW Launcher Ex- DarkEdge Red Theme
Homescreen Widgets: Calendr and Minimalist Text
What you get:
-Red (#f50000)
-Red Glass look
Custom Popups
-Transparent Grey
-Red (#f50000) Glow
.NOW AVAILABLE AS A VelocityMorph Theme!!
5. Option 1
6. Option 3
7. Option 1
They do the rest!
RedEyeBootanimation
Screen shots:
