cool.gautam
Hey guys afterflashing about 1000 times in past 1 month i am able to create a rom with flash + everything working frgot rom toolbox download it from anywhere and install ...pay me regards by hitting thanks
Hybrid v2-
FEATURES--
some cool apps
ziplaign at boot
some add-ons
app2sd
bash
nano
adw launcher
dalvik to sd
vm 38
removed mmx apps
tweaks
jit enabled
loopy smoothness tweak corrected
ramscript
working flash with stock browser
framework customizations( removed created lag)
Some build prop tweaks enable them by rom toolbox and reboot
CREDITS-- Varun for buildprop tweaks
Sam for suggesting name of rom![Wink ;) ;)](/styles/smilies/google/wink.png)
DISCLAIMER -- Try Flash with kernel IF NECESSARy....FIRST TRY INSTALLING AS IT IS
[ROM]
1)Go back to stock
2) reboot to recovery
3) wipe dalvik cache
4) select install zip from sdcard and select the rom
4) reboot
link = Multiupload.com - upload your files to multiple file hosting sites!
[ FLASH PLAYER ]
Download adobe flash player ans install simple
YOU CAN CHECK FLASH BY VISITING whatismyflashplayerversion.com from your stock browser
IF , problem while connecting usb
1) connect to pc/laptop
2) go to settings--> applications--> development
3) USB debugging will have a tick against it...
4) First untick that it will show USB connected and then again tick that it will start debugging
5) u will have to do this only first time
[KERNEL FLASH ONLY IF REQUIRED ]
1)reboot to recovery menu
2)wipe cache and dalvik cache
3)flash kernel
4)reboot
5) reinstall flash if not working above
DON"T FORGET THANKS..
Hybrid v2-
FEATURES--
some cool apps
ziplaign at boot
some add-ons
app2sd
bash
nano
adw launcher
dalvik to sd
vm 38
removed mmx apps
tweaks
jit enabled
ramscript
[ROM]
1)Go back to stock
4) reboot
[ FLASH PLAYER ]
3)flash kernel
4)reboot
