dudeman1996
Android Expert
mikegapinski is porting the latest version of Android - 4.0 Ice Cream Sandwich!
Most of the features are finished a couple are broken/partially working. But here's what there is so far:
- USB/WIFI Tethering - Working with alternative apps
- RIL - Working
- Sound - Working
- Headset - Working
- Touchscreen - Working
- HW/3D - Working
- Screen - Working
- ADB - Working
- SDCard - Working
- Vibration - Working
- Sensors - Working
- WiFi - Working
- 3G - Working
- Bluetooth - Working
- GPS - Working
- Camera - Not working
Screenshots:
Beta 4 Changelog:
How to install:
Simply download the following .zip file, copy it to your SD Card, and flash it through recovery. If you don't know how to do this, reply to the thread and I'll let you know Also, if you're upgrading from Android 2.3, you have to wipe your data before flashing this .zip (again if you don't know how, reply to the thread).
CyanogenMod-9.0.0-RC0-OPTIMUS-BETA4_Mike_Gapinski.zip
- RIL - Working
- Sound - Working
- Headset - Working
- HW/3D - Working
- Screen - Working
- ADB - Working
- SDCard - Working
- Sensors - Working
- WiFi - Working
- 3G - Working
- GPS - Working
Screenshots:
Beta 4 Changelog:
-The red shit is gone 100%
-EGL Hack is updated(performance)
-WiFi turn on issues are gone
-Edited prop for power safe(maybe it will last more)
-CM is most current now
-Kernel Build Number is #666 so god is watching
-Little errors are gone
One more thing – animations are liquid smooth now but I would recommend to change launcher to other for better performance O forgot to fix the time shit in frame so this is not working ! The battery life was tested by a few pepole – results are:
Total time 55:40:11, deep sleep 48:54:42 (Idle)
Total time 23:40:11, deep sleep 14:54:42 (Blend)
Total time 18:46:21, deep sleep 8:54:42 (Hardcore Angry Birds on Math)
If it won’t work go to Settings-WIFi-Advanced and turn the „Keep Wi-Fi on during sleep” to never or only when pulgged in And remember to flash on full battery and wipe the stats in recovery. It has to work now
Kernel Changes:
- New power and batt drivers from .29(using LG charging table, so now percentage is correct)
- Charges to 100%
- Console Switch on Early Suspend(working on ICS deep sleep alternative)
- CPU freq drivers from 3.0 Galaxy Nexus Kernel
- SWAP is enabled I think, test that
Now battery life is better I think but that needs testing still For best battery get SetCpu and set governor to smartass and set min clock to 122/245.
Kernel Changes:
- Charges to 100%
