Crossfade4
My LG Marquee was updated last nite, it was a software upgrade, does anyone know what this was for? my android version is 2.3.4 is their any chance the marquee will run honeycomb or ice cream sandwich? thanks for any help on this!
The update was for certain bug fixes and I heard, yet haven't seen, that it also removes Carrier IQ. Most likely since Sprint has announced it will be putting the Marque on the EOL (End of Life) list at the end of this month that we will not see an official HC or ICS ROM. Possible one day that a dev may decide to make a Custom ROM that will be as close to it as we can, but that is not certain.My LG Marquee was updated last nite, it was a software upgrade, does anyone know what this was for? my android version is 2.3.4 is their any chance the marquee will run honeycomb or ice cream sandwich? thanks for any help on this!
If you install the update from boost, you lose root and there is no exploit to allow the updated version to be rooted. Only way is to go back to pre-update state by restoring a cwm backup or flashing back to original stock and then updating using one of the modified update zip files available on this forum: http://androidforums.com/marquee-all-things-root/527372-boost-zvc-zv4_21-cwm-flashable-update.html. Good luck.Need help. I used to have my LG marquee rooted and after a update from boost now I cant get any permission of superuser. Anybody can help me? Also need detailed instruccions because I am new on this and I am not a computer geek. Thanks. If some body give me his email, I will send a report of my Root Check Pro. Also will donate.
Odd, I updated and still have Carrier IQ. It made my score lower went from 700's to 400's. I am not quite sure what to think of this update overall..i ran a carrier iq check app and it definately removed it. i just bought the phone 2 days ago im wondering if they are gonna eol it if i should return it for a different phone, but i do like the phone tho but at the same time would like to b running hc or ics. anyway thanks for ur help my friend
Manually update by following the instructions posted here:Hell, mine has attempted update twice with no luck. Update does not go through. I will trade my root access for the fix to the power cycles happening during calls.
i have a sprint lg marquee and had root untill the update was pushed through. root worked fine untill the update then everything went downhill. i used root checker to conform root and it said no root yet google movies says im rooted. su cannot be deleted and the su file and all other files in the root/system/bin folder are gone. root/system/app has superuser.apk and root/system/xbin has su. im looking to return my phone back to stock.
MN: lg-ls855
android ver.: 2.3.4
sw ver.: ls855zvc
I am having that same problem I haven't been able to get it fixed
Please tell me how did you root your lg marquee. This is my email shawntee.weeks@gmail.com
