scudder
Android Expert
Odd thing that just happened that I want to share regarding LauncherPro and custom fonts after flashing Gingerbread 2.3 and, hopefully, get some feedback about...
So I nandroid backed up, wiped dalvik (albeit with a little "E: Can't mount /dev/block/mmcblk0p2" issue) and flashed the ROM. I rebooted and everything loaded up fine..looked great...LauncherPro loaded up...all my customizations on my LauncherPro home screen was good to go...I had Gingerbread! Everything looked fine EXCEPT I noticed that I lost my custom font!!?? I installed the "Decker" font months ago as a replacement for my system font while I was using froyo by following instructions at a link at XDA:
300 Flashable Font Packs - Change your system fonts the easy way! - xda-developers
Simple flash technique...download the font pack, flash the zip, reboot.
And HERE my problem...
After flashing the font, my phone booted up in Sense, not LauncherPro. No problem I thought...I could just launch LauncherPro, re-establish it as the default launcher, and I would be back.
NOPE...NOT working...and here is the ODD thing...
I CANNOT launch LauncherPro at all! It was NOT showing up in my app drawer even though it was listed as "installed" in Titanium Backup. Also, I could not even RUN the app from within Titanium Backup...the "run app" button was NOT SHOWING.
I uninstalled LauncherPro and then went to the Market to reinstall. Download and install process went fine but, once again, LauncherPro did NOT show up in my app drawer and could NOT be launched from within Titanium...?? I even tried to reinstall the app via Titanium...the option to reinstall was available and process seemed to occur but STILL nothing!!
So, I AM nandroid backed up so I am not too, too nervous but this is QUITE a weird situations. I am not sure why this happened and was wondering if anyone might know the reason why and how I can FIX??
I read that perhaps the issue is that the fonts I was using in the above link to customize the phone under Froyo might NOT work with Gingerbread...that Gingerbread perhaps requires the newer EDIFY fonts?? Could that have caused the mess up that I experienced??
I RESTORED my nandroid backup so, as I am writing this, I am using Gingerbread 2.3 but my custom fonts are lost. LauncherPro IS my Launcher that I am currently using, HOWEVER, someone REALLY WEIRD!!..I just went to look at my app drawer and LauncherPro is NOT THERE!! Also, I went to the list of my installed apps in Titanium Backup Pro and although LauncherPro is listed, the "Run App" button is MISSING!!
Why is LauncherPro not in the app drawer?? Why can't it be launched via Titanium? And why did Sense replace LauncherPro (with NO WAY of getting LauncherPro back at the moment) when I flashed a custom font? Any thoughts??
THANKS!!
THANKS!!
