Mostly Harmless
Android Expert
When a newer version of CM comes out how do you go about updating it? Do you lose all your settings?
So i can download it directly from Rom Manager and then use clockwork recovery to install it? Sorry for the questions, first time I am diving into this.
I'm anti ROM Manager and think it should be avoided like the plague. From my experience I have seen it cause nothing but problems.
) It's an easy way of installing a nightly build, when we get to that. Most builds of CM7 come with RM and don't have a power menu item to boot into recovery so it's the only way to get there. The only place I've seen problems with it is on the DroidX, which has other apps that install recovery. RM is a shell for CW recovery and just creates a script to automate it, saving your volume buttons.
