can someone confirm that. when i had to SBF 2.1,for some reason i remember losing everything that wasn't on the SD card...
my build prop is the exact same as yours lazer. so could we get a original build prop and replace it?
ro.build.version.incremental=2.3.9
ro.build.version.full=Blur_Version.2.3.9.MB810.Verizon.en.US
and on a side note. i just tried the OTA. and it said i was up to date.
I'm on ApeX so I dont know that my build props would work for you guys
Lazer- howd you get yours to report out like that so I can try to post mine for you guys
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=VZW
ro.build.display.id=Apex 1.0.2.2
ro.build.version.incremental=2.3.15
ro.build.version.sdk=8
ro.build.version.codename=REL
ro.build.version.release=2.2
ro.build.date=Wed Sep 1 21:13:50 CDT 2010
ro.build.date.utc=1283393630
ro.build.type=user
ro.build.user=w30471
ro.build.host=il93lnxdroid08
ro.build.tags=test-keys
ro.product.model=DROIDX
ro.product.model.internal=MB810
ro.product.brand=verizon
ro.product.name=shadow_vzw
ro.product.device=cdma_shadow
ro.product.board=shadow
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=motorola
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=omap3
# ro.build.product is obsolete; use ro.product.device
ro.build.product=shadow_vzw
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=cdma_shadow-user 2.2 VZW 2.3.15 ota-rel-keys,release-keys
ro.build.fingerprint=verizon/shadow_vzw/cdma_shadow/shadow:2.2/VZW/23.15:user/ota-rel-keys,release-keys
# end build properties
# system.prop for CDMA Shadow
# rild.libpath=/system/lib/libril-moto-umts-1.so
rild.libpath=/system/lib/libmoto_ril.so
rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=240
ro.default_usb_mode=2
# BEGIN Motorola, a18772, 05/19/2010, IKSHADOW-5584
# Add 411 to DAN List for VZW.
ro.mot.ril.danlist=611,*611,#611,411
# END IKSHADOW-5584
persist.ril.ecclist=911,*911,#911
persist.ril.modem.mode =1
# This defines the max event window manager can
# handle in 1 s. We may adjust this # for performance
# reason later
windowsmgr.max_events_per_sec=68
# This defines the min duration between two pointer event
ro.min_pointer_dur=10
# USB modes allowed for UI and switching
ro.ngp_available=1
ro.modem_available=0
# Default network type.
# 4 => CDMA / EVDO.
ro.telephony.default_network=4
ro.com.google.clientid=android-motorola
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.cdma.home.operator.numeric=310004
ro.cdma.home.operator.alpha=Verizon
ro.config.vc_call_vol_steps=7
# wlan interface
wifi.interface = tiwlan0
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
wifi.supplicant_scan_interval = 120
# Indicate carrier OTA SP number schema
# refer to frameworks/base/telephony/java/com/android/
# internal/telephony/cdma/CDMAPhone.java for the schema:
ro.cdma.otaspnumschema=SELC,1,80,99
# The OpenGL ES API level that is natively supported by this device.
# This is a 16.16 fixed point number
ro.opengles.version = 131072
# This is a high density device with more memory, so larger vm heaps for it.
dalvik.vm.heapsize=48m
# The URL for safety information
ro.url.safetylegal=http://www.motorola.com/staticfiles/Support/legal
# our HTML browser (not WAP browser ) does not need to specify UAProf URL
ro.mot.hw.uaprof=
# Enable HAC to also display Call Setting Menu Option.
ro.mot.hw.HAC=1
# Motorola, a19622, 12/28/2009, IKSHADOW-204 / Location Settings for android
# Property to set enabling state of the location privacy setting feature.
# Motorola, a19622, 03/16/2010, IKSHADOW-2141 / Disable feature 33067
#ro.mot.settings.locprivacy=1
# ERI feature
# 0 OFF
# 1 ON
ro.mot.eri=1
# Motorola, a22976, 13/5/2010, IKSHADOW-5203
# Delay for Loss Of Service alert
ro.mot.eri.losalert.delay=2000
# If time from last RoamInd change to SID change less than below, not play alert
ro.mot.eri.sidalert.delay=1000
# END IKSHADOW-5203
# Motorol,a6889c,02/Feb/2010,IKSHADOW-619
# Proximity Sensor feature
# 0 disable
# 1 enable
persist.mot.proximity.touch=1
# End IKSHADOW-619
# BEGIN Motorola, a22976, 25-Feb-2010, IKSHADOW-702, FID 31841
# VZW Requirement Specifications: NETWORK BASED PLUS CODE DIALING
# 0 disable
# 1 enable
ro.cdma.nbpcd=1
# END IKSHADOW-702
# BEGIN Motorola, a22976, 12-Mar-2010, IKSHADOW-1784, Power Up Tone
# Motorola, a22976, 12-Apr-2010, IKSHADOW-3298, Remove temporary power up tone
# BEGIN Motorola, wbdq68, 21-May-2010, IKSHADOW-3372, Turn ON Power Up Tone
# Motorola, a22976, 26-May-2010, IKSHADOW-6164, Remove power up tone to keep the same as Droid
#persist.mot.powerup.tone=/system/media/bootup.ogg
# END IKSHADOW-3372
# END IKSHADOW-1784
# BEGIN Motorola, a22417, 22-Mar-2010, IKSHADOW-2345,default data roaming is on
ro.com.android.dataroaming=true
# END Motorola, a22417, 22-Mar-2010, IKSHADOW-2345,default data roaming is on
persist.mot.a2dp.direct = 0
# System property for SMC
ro.service.start.smc=1
# BEGIN Motorola, a21951, 17-Apr-2010, IKSHADOW-3602
# 0 disable
# 1 enable
persist.mot.usb.mediasync = 1
# END Motorola, a21951, 17-Apr-2010, IKSHADOW-3602
#Proximity sensor debounce time
mot.proximity.delay=150
# disable touch below 60 pixels
mot.proximity.distance=60
# BEGIN Motorola, pkd348, 26-Apr-2010, ISHADOW-4035
# true Horizontal BUA is preloaded, not allow to install standalone version of BuA from Android Market
# false Horizontal BUA is not preloaded
ro.HorizontalBUA=true
# true Horizontal VVM is preloaded, not allow to install standalone version of VVM from Android Market
# false Horizontal VVM is not preloaded
ro.HorizontalVVM=false
# BEGIN Motorola, a22976, 21-May-2010, IKSHADOW-5385
# For Shadow only, NOT applied to Droid2 as requirement different
ro.mot.buttonlight.timeout=0
# END Motorola IKSHADOW-5385
ro.mot.master_clear.shredsd=false
# BEGIN Motorola, pkd348, 09-July-2010, IKSTABLEONE-1236
# true enable the feature of In case of Emergency, default is false
# false disable the ICE feature
ro.mot.fid.29967.ice=true
# BEGIN MOTOROLA, vfhk68,24-July-2010, IKSTABLEONE-2469
# true enable the feature of 33531
# false disable the feature
ro.mot.fid.33531.keylock_ecm=true
#END
# ADDITIONAL_BUILD_PROPERTIES
ro.kernel.android.ril=yes
persist.ril.mux.noofchannels=7
persist.ril.mux.ttydevice=/dev/ttyS0
persist.ril.modem.ttydevice=/dev/ttyUSB0
persist.ril.features=0x07
persist.ril.mux.retries=500
persist.ril.mux.sleep=2
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
media.stagefright.enable-player=false
media.stagefright.enable-meta=false
media.stagefright.enable-scan=false
media.stagefright.enable-http=false
ro.default_usb_mode=0
ro.product.multi_touch_enabled=true
ro.product.max_num_touch=2
ro.telephony.sms_segment_size=160
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=2.2_r5
ro.telephony.call_ring.multiple=false
ro.telephony.call_ring.delay=1000
ro.url.safetylegal=http://www.motorola.com/staticfiles/Support/legal/?model=A855
ro.setupwizard.enable_bypass=1
ro.com.google.clientidbase=android-verizon
ro.com.google.clientidbase.am=android-verizon
ro.cdma.homesystem=64,65,76,77,78,79,80,81,82,83
ro.cdma.data_retry_config=default_randomization=2000,0,0,120000,180000,540000,960000
ro.com.motorola.smartsensor=true
ro.media.capture.maxres=8m
ro.media.capture.fast.fps=4
ro.media.capture.slow.fps=60
ro.media.capture.flash=led
ro.media.capture.classification=classD
ro.media.capture.useDFR=1
ro.media.camera.focal=3564.0,3564.0
ro.media.camera.principal=1632.0,1224.0
ro.media.camera.skew=0.0
ro.media.camera.distortion=0.0,0.0,0.0,0.0,0.0
ro.media.camera.calresolution=3264,2448
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.mot.hw.uaprof=http://uaprof.motorola.com/phoneconfig/MotoMB200/profile/MotoMB200.rdf
ro.build.version.full=Blur_Version.2.3.15.MB810.Verizon.en.US
ro.config.ringtone=Moto.ogg
ro.build.config.version=GAS_NA_GCXSHAD00VZW_P022
ro.build.config.date=Wed_Sep_01_21:13:04_-0500_2010
Thank you ECF.. I did the two changes I quoted in http://androidforums.com/1974610-post29.html to reflect to the 2.3.15.. Repushed. Rebooted. and now I'm at the 2.3.15 as the version. Tried the update but as mentioned elsewhere it is possibly not available atm so time will tell.
awesome! thats one down. now what about being deoxed? has anyone updated with that still in the phone?Thank you ECF.. I did the two changes I quoted in http://androidforums.com/1974610-post29.html to reflect to the 2.3.15.. Repushed. Rebooted. and now I'm at the 2.3.15 as the version. Tried the update but as mentioned elsewhere it is possibly not available atm so time will tell.
Laser
Can I do this on my phone somehow? I am not at home right now.
Or maybe attach your file? (this would be best as we could keep build edits from xda)
I also got an original 2.3.15 from a friend...he's never even rooted his phone and hasn't updated to 2.3.40 yet. So I have that if it's needed.
Thanks for the zip Lazer..works great.
Sure. Just zipped it for you. Note I only made those two edits so fingers crossed but I'm booted back up fine. See instructions at bottom of OP to get pushed to phone --> Build.prop edits = great battery life + fast phone + full market
Back to my original question for a moment... Sounds like the suggestion was to sbf to 2.1 then follow all the OTA upgrades? Are there update zip files available that would allow me to go upgrade from my current setup to the newest update?? Thanks!
Well, while the files did change my version number on the phone, there is evidently still something wrong with the file. I downloaded and tried to install the update - there is a link here on the main page of this site - installing the file indicated an error in build.prop.
So...two questions:
1) Does a factory wipe recreate an original build.prop file?
2) Does someone have an ORIGINAL, unmodified, same as new build.prop file?
Thanks.
Just discovered this via above method myself.I found a site with all the "Back to Stock" files we need. The link to the page is:
[Theme] 928Droid Black Glass X for Droid X !!! - Droid Forum - Verizon Droid & the Motorola Droid Forum
Search that page for another link to the Droid X Back to Stock files, and search the page that loads for "back to stock". There are two zip files. One for "Deoxed" and one for "Odexed"
And, it sounds like Deoxed has something to do with Themes - and I've never done that, so while I'm downloading both files, I'll be using the Odexed file.
