jcarlosfox
Member
EDIT: This solution ONLY works if you are running a STOCK 2.2.15 installation, but your version number is incorrect because you installed a "build.prop" file from another version or from a site on the net. Many of us, me included, installed a version of build.prop from the leaked version, and our version number changed to 2.2.39, even though we had not installed the leaked version. So, if you DID NOT install the leaked version of 2.2, and have had trouble installing the update, and you received a failure warning that mentions build.prop, then this solution might work for you. Bottom line, make sure you keep a backup of your build.prop if you mess around with the file. You never know when you might need it.
Original post:
Success!!
I removed the existing build.prop file from my system folder, and placed the attached file in its place.
Turned off my phone.
Turned it back on in recovery mode (Hold the Home Key and the Power key until you get a little Android guy, then click the search button.).
Asked the phone to install from update.zip (the file downloaded from this site, and placed on the root directory of the SD card.)
The install ran normally.
Clicked the option to re-boot the phone.
Rebooted normally - although it seemed to take a while for the android eye to go away.
All appears well. Phone reports it is Version 2.3.340.MB810.Verizon.US
I did LOSE ROOT ACCESS.....but that is a topic for another thread, and something that has already been resolved.
Happy camper.
Original post:
Success!!
Happy camper.
