Upgrade from Eris
metzy75
Member
I am able to get an upgrade tomorrow and I am curious if you guys the owners of this phone are generally happy with it? I would be coming from the Eris and I want to know any information on whether I should get this phone or another in the Verizon line up?
I would suggest waiting a little while before upgrading and get either the rezound or the nexus, they are both due out this month. You could also look into the razr but I don't like moto very much anymore so I wouldn't suggest going with it.
I love my phone but I have put a lot of effort into it and making it how I like it.
Are you in an LTE area? If your not I'd suggest getting an Incredible 2 over a TB. They're very similar spec wise, the Inc2 just doesn't have an LTE radio & its .3" smaller. This recommendation is based on the fact you don't want to spend $300 on a Rezound or Nexus.
If you haven't decided, I would go with the T-bolt.
1-Been out for awhile, alot of issues with phone have been worked out.
2-Plenty of support/developement out there for the device. Root it and the potential of the phone is awesome.
3-Being an older model, gonna be dirt cheap
4-Sure NEW (as in model) is nice, but gonna be less support just cuz so new and it WILL have issues.
My .02
HTH and good luck with whatever you decide
