dahookup29
I want to upgrade my system but my phone is flash n I heard if you do it can erase everything. So I guess I need a custom rom, kernel or something. I'm new to the android system n don't know much about it
I believe that you can flash a custom rom such as MikG v3.11 which comes with its own kernel...I'm flash to boost mobile, running Android 2.2 Baseband version 2.15.00.11.19
Hboot-2.10.0001 and the S-off
MikG v3.11 [3/9/2012]
And instructions how to flash....post 3, skip step 4
Can we flash over the old ROM?
But before we do that, I/we would like to know what kind of recovery you have.
We recommend Amon RA....if you have clockwork recovery, that can be changed.
While in the bootloader screen hilight recovery and press power to get to recovery and let us know what that says. k?
I'm using ClockworkMod Recovery v2.6.0.1
Ok where's the link?OK. That's the first thing to change. On phone now but will post a link. K?
Ah yes, forgot, thanks!Once you update your recovery make sure that you delete the zip file from your sd card otherwise it will try to install on each reboot.
