Root [URGENT]Help with un-root. No SD!
Here's my complicated problem. My phone was stolen recently so I went to asurion and got a new Evo 4g. happy has I was while installing a Supreme Classic for the Classic ROM. Something went wrong and I can no longer read the SD card. Then something else went wrong and I have no recovery. I was stuck in bootloader loops for awhile until I ran a RUU and went to stock rom. Now on stock rom, I have constant restarts that will not allow me to charge the battery or anything. What I want to know is...
Is there a way to fix it without sending it to HTC/Sprint, because when you load bootloader it still says revolutionary, however it does not show that I have a recovery rather a Red Triangle.
Or...
If there isn't a way to fix it, how can I unroot it and leave it at stock ROM without an SD card since, it will not read as I stated above it continues to say unavailable but card readers can read it.
Please assist I'm in dire need of my cell phone,
P.S I'm new to the forums. Also is still S-OFF
Or...
out of curiosity what recovery where you using before all this happened?
do you have card reader?
I had revolution. At least that's what it said on the background. I was also trying to flash amon ra before it occured the it wouldn't let me access the sd card suddenly. Yes I have a card reader.
ok try and get amon ra installed first. so go to the switching recoveries section of the http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html and follow directions on how to get amon ra installed. once we have that in place lets see if we can wipe and flash a rom and see if that helps out the situation.
Okay, but how am I able to do this if my phone doesn't read the SD card, therefore revolutionary won't read it. And also.. at the same time the phone is randomly rebooting.
I am able to boot into the phone fine. I can use the phone, but it'll reset within 30 seconds - 2mins. When i go to SDcard and phone storage. It shows unavailable. Before when my recovery was fine, the card would not mount or work in anything with recovery. The SD card is fine because I have used it in the card reader. I also have 3 other spare ones which I tested with. All cards are working.
what size is your card? and have you re-formatted the card?
and just for curiosity's sake lets try and get you amon ra and see if the card will work in the bootloader. who knows it might just decide to work anyways.
Yes, bootloader loads fine. I flashed my stock ROM with the bootloader via PC36IMG. But, when i try to flash recovery it only goes back to the bootloader. My hboot is 6.16.1002 if that helps any.
Yeah, it does ask for an update. I believe right now. I'm unrooted with the sd card not reading. But it still shows revolutionary s-off and the bootloader. no recovery. right now. i'm just trying to find a way to get rid of the REVOLUTIONARY and s-off. Unless there's a way to fix my phone being able to read the sd cards again.
