JonniBravo
Hi I've had a number of problems with this phone and now I'm stick on usb nrick. I have tried the fix but I am stuck at the start.
When I enter fastboot own boot I get this;
>fastboot oem boot
(bootloader) setup_tag addr=0xA0000100 cmdline add=0x8E07F9F0
(bootloader) TAG:Ramdisk OK
(bootloader) TAG:smi ok, size = 0
(bootloader) TAG:hwid 0x0
(bootloader) TAG:skuid 0x21F04
(bootloader) TAG:hero panel = 0x0
(bootloader) TAG:engineerid = 0x0
(bootloader) MCP dual-die
(bootloader) TAG:mono-die = 0x0
(bootloader) Device CID is not super CID
(bootloader) CID is T-MOB005
(bootloader) setting->cid::T-MOB005
(bootloader) serial number: HT******18
(bootloader) commandline from head: no_console_suspend=1 msmsdcc_sdioirq=
(bootloader) 1 wire.search_count=5
(bootloader) command line length =456
(bootloader) active commandline: board_bravo.disable_uart3=1 board_bravo.
(bootloader) usb_h2w_sw=1 board_bravo.disable_sdcard=0 diag.enabled=0 boa
(bootloader) rd_bravo.debug_uart=0 smisize=0 userdata_sel=0 androidboot.e
(bootloader) mmc=false androidboot.baseband=5.17.05.08 androidboot.cid=T
(bootloader) -MOB005 androidboot.carrier=TMUK androidboot.mid=PB9920000 a
(bootloader) ndroidboot.keycaps=qwerty androidboot.mode=normal androidboo
(bootloader) t.serialno=HT07DPL03118 androidboot.bootloader=0.93.0001 no_
(bootloader) console_suspend=1 msmsdcc_sdioirq=1 wire.search_count=5
(bootloader) aARM_Partion[0].name=misc
(bootloader) aARM_Partion[1].name=recovery
(bootloader) aARM_Partion[2].name=boot
(bootloader) aARM_Partion[3].name=system
(bootloader) aARM_Partion[4].name=cache
(bootloader) aARM_Partion[5].name=userdata
(bootloader) partition number=6
(bootloader) Valid partition num=6
(bootloader) jump_to_kernel: machine_id(2457), tags_addr(0x20000100), ker
(bootloader) nel_addr(0x20008000)
(bootloader) -------------------hboot boot time:20437 msec
FAILED (status read failed (Too many links))
finished. total time: 4.786s
there is no infotag, like what the instructions say. googled this and there is no info on this?[/QUOTE]
Sent from my HTC Desire using XDA App
>fastboot oem boot
