Help Usb otg
DOOBEE
I have been using this feature a lot recently and it works brilliantly, but only when you hard-drive is formatted to FAT32, limiting the file sizes to 4GB. the only problem is that im using my general external hard drive that i use to back up all my data, and some of my files are over 4GB.
i have tried creating partitions on the hard drive, and having the FAT32 as the primary partition, but as soon as there is a NTFS partition on the drive the phone wont recognize that anything is connected.
Has anyone got any ideas for a work around for this?
Hard drives should not be fat32 really, they should be NTFS and the SD Card should be FAT32
