Root USB printing?
rootbrain
Has anyone been able to print via usb otg from their Nexus 7? Would be a great feature, not sure if it's doable. But there have to be linux drivers for most of the newer printers out there that might work, so just wondering if anyone has done it or heard anything.
TIA
IDK, I would think it should be possible somehow. But I can't try it at the moment so I will try later
Thanks. Using USB OTG dongle I can connect my Dell Laserjet and using USB Host Diagnose app, it does recognize it as USB device, just not sure how to proceed. Pretty sure I'm going to need the printer driver. Will look for it, and see if I can find out how to install.
What printer do you have?
Pay app https://play.google.com/store/apps/details?id=com.dynamixsoftware.printershare
Only bad reviews are because it's free to download, in app purchase to print. 12.95.
Haven't tried it. I was looking at the cannon printer app, and all the reviews are people crying because all you can do with that is print pics and use the scanner wireless.....
Yep, seen the wireless print apps, but I have a Dell laserjet without wifi, only wired USB so was wanting to use that to print if needed. Going to need a linux printer driver I'm pretty sure. maybe a generic postscript driver would work. Still looking around.
Reviews say they were able to print USB with dongle
You have a link? I have USB OTG dongle, recognizes a USB device but not as a printer. Perhaps I need to use terminal with the lpt command and set up the printer via unix?
I only know basically, but could Google it I guess. But any strong Linux sys admins maybe help with that it would be greatly appreciated. The Dell laserjet I have can be used as generic postscript printer, although there would be some things that wouldn't format correctly I'm sure. Most would though.
TIA
I've used this app, bought paid version a long time ago. Just spits blank pages with my Brother DCP7065DN, but works with a old HP Laser jet 1000. over Wi-Fi so its kind of a shot in the dark. The publisher itself is also very rude in dealing with costumers and difficult to get a hold of.
If you miss the Google return window and it doesn't work for you kiss your money goodby.
Jove, appreciate the link again, sorry I didn't understand. However, I'm looking for usb printing (per the thread title) because I don't have wifi to my Dell laserjet, so this app isn't workable for me.
Reviews say it works USB. but like the guy above me said, its a shot in the dark. And it costs $13.
Is it possible to set up your printer as a Google Cloud printer, via your PC? Then not only could you print wirelessly, but you wouldn't even need to be on your home network to do it...
I think I need static ip's for that don't I? Everyone has 192.168.x.x internals and if I use my providers ip, hows it know which 192 to go to from there?
If anyone has a link on how that can be done with dynamic ip's I'd appreciate that. Any info would help, but really just a printer driver so I can plug my USB laserjet into the Nex7 would be much simpler I would think.
Still looking.
