Tech support told me to take to to the nearest Verizon store and have them check it out. I switched the sd card with another one and it worked. So what im thinking is that all of those files im trying to transfer are on my internal storage and not my sdcard like they should be. When i access astro it all shows up under my sd card. What i get to show up on my ps3 is sdcard ext. When i look at available storage space internal total i have 8 available i have 3.77 sd card it says i have 14.78 and available is 14.55. So i think my music is on the internal memory even though it shows up on my sd card in a music file on astro. How do i fix this.
Astro reads it fine. SDCard is your internal memory while SDCard-Ext is external removable SD Card. You can move your files form the internal to external via astro or a computer would be the fastest. You are not rooted at all are you?
