Lol.. The CRAPtivate.. The crappy cappy.
Never mind. Problem fixed (5 minutes after I posted this and 3 hours after I started trying EVERYTHING to get it to work).
I have struggled with getting USB connection to both my Win7 and Vista machine for days now.
- Downloaded and installed Samsung USB drivers. 3 Hours of rebooting and trying various phone USB configurations and modes came up empty. My Win machines never detect a USB connection.
- Downloaded Kies 1.5.1 and installed. Full day of rebooting and various phone USB configurations again. Once, and only once, did my phone appear in Kies. All subsequent attempts (reboots/reinstalls/phone settings) have failed.
- My phone is not running Launcher Pro or any other widget
Why am I not surprised...my wife and kids are running around with Samsung Solstice phones and guess what...they don't connect via USB to Win either. Lots of hours lost there as well. Curse you Samsung!
My only need for connection is to copy/share media files - all my contact and calendar stuff comes from Google account.
My "solution" (thanks ZDroid1) is swiFTP. Works like a champ.
1) Did you try connecting before installing any drivers?
2) Is your USB set to "Mass storage"? Menu -> Settings -> Applications -> USB Settings.
3) Have you tried a known, working cable? I knew someone who would've sworn on their mother's grave they had a bad iPod because they couldn't sync and had tried 2 cables. Turns out they had two bad cables. Trying a third, known-working cable worked fine.
4) Have you tried all the USB ports on the computer? Some people have reported issues with some ports.
I restarted the phone itself ! Go figure. I think the Galaxy S 64 drivers is what worked, but I got the Captivate ones installed as well. I'm running Windows 7 64 bit.
It seems restarting the phone was crucial. I never did that in my previous attempts. Also before mounting the phone, my computer shows no sign that a usb device is present. And even then it takes a while to appear.
