2 Questions.
1. Does DT's A2SD automatically move the Dalvik cache to the sd card as well or are there extra steps for that?
2. Am I understanding correctly that this method will actually format the card and get rid of the original partition I still have from when I installed A2SD with Icarus? I was going to try your Linux method but haven't gotten around to it yet and I do like A2SD better than Apps2SD or whatever it's called.
OK, 3 questions. I have a spare sd card or two. I should be able to pre-format my larger card with everything I need, put in my smaller card, wipe everything and then swap to my larger card to flash CM7, gapps, ect instead of having to hook up the phone, dl and do all that battery dropping stuff, right? I dunno. Somethings wrong with this line of thinking but I'm not sure what it is. Am I missing something?
Edit: I see. I didn't read the instructions very well. I would still have to remove the card, hence having to remove the battery and drop back into place. Is it really necessary to hold power, volume and call buttons while dropping the battery in? Might it work out ok if I just put the battery in and then quickly press the three necessary buttons?
Do you have a link to this a2sd zip download?
How is DT's a2sd different from the a2sd that is already in the CM7 05142011 for the ascend?
1. NO by default it stays internal. You just go to terminal and type " a2sd cachesd " (w/0 quotes) and it moves it over.
2. NO, not really, you would need to go into a linux OS to get rid of the EXT. you could "Probably keep" the icarus type partition. Remember this is for with CM7. Personally, I would start fresh, go to linux Ubuntu or something, use gparted, make 1 big fat32 partition, then format and partition within clockwork just to be safe that it's totally clean from the start
3. NO your right, I did that before, I had the zips on another SD, put it in flashed and switched, had DT a2sd on the "Final" card and used it after all was cool. I don't know I just got used to using that method, it's silly I know, but it really works, switching cards back/forth is sometimes messy as when you flash CM7 / kernal update/gapps/etc. it will put stuff on the card, so you want to keep that card as the final. Your right though, you could probably do it that way no prob. Just have the ext3 part. and swap part. on the "Final card"
YES, it is possible if you put in the battery and real fast press the buttons, I just do that so that the instant it has power, it sees the buttons pressed, but I did a couple times toss in the battery and hurry and hit the buttons.
Also, yea your right, you have to switch the cards anyway, so might as well do it that way.
OK, keep me posted, I will do what I can, mine is running like a charm for a bit now, so NO problems. When your done, just go to terminal type " a2sd check " and read thru, you'll see any problems. OR if you type a2sd help, it will tell you all the commands, including those about moving the Dalvik....
GOOD LUCK...Jeff
Thank you, Jeff. It will probably be a while before I get around to it, could be weeks or it could be two or three hours from now if I can't sleep or something. I try not to second guess myself too much but sincerely, thank you for posting this information.![]()
Ok just tossing in kudos here. I had cm7 already flashed when I installed dta2sd. All I did was format my card in cwm2158 and partition using your numbers. Rebooted and put a2sd.zip on SD.
Reboot cement and selected "install zip from sd"
After reboot I ran the same commands as for Icarus. All works perfect. Thanks jeff!
But i don't get it; can't you already move your apps to the SD? or is it much better to do the process in your thread?
FYI, I don't see the need to hold buttons while trying to drop in the battery as well, you almost need three hands for that. I've never had an issue with inserting the battery and having the phone power on automatically, provided you wait for a good 10 seconds or so after removing it. Drop it in, hold Send+Vol Up, then press Power, should boot into Recovery as usual.
please read the PM i sent uKevinRubino:
Do me a favor, I saw your PM with these exact questions, will you please post my answers for the benifit of others.
I didn't realize you had it on the thread, I just saw your PM with the exact same thing. Please put on the thread.
Thanks.
Jeff
Also, please, no biggie, but just ask 1 place or the other. Better on the thread so all can see.
Then if I don't see it, send a PM, saying HEY ANSWER MY THREAD QUESTION!
That will streamline things..
Thanks.
Good luck.
Jeff
okay....it seems to me that all of this really wouldn't matter or even make that much of a difference if the phones RAM is set at a specific Max. Apparently our phones have an internal SD as well as the RAM.....now I can see how your process would help if the RAM is governed by virtual memory (meaning that the phone would increase the RAM if there's more internal memory available) but however if the RAM is set the only thing I can see that would actually have anything to do with improving the phones speed and performance is the compression option in the performance settings. otherwise from my understanding all you guys are doing is freeing up certain system processes stored on the internal SD that might normally be using a certain amount of your RAM at all times......So in a sense it would be no different than killing process running in the background, except without having to kill them
