n4zty
Android Expert
Well since discussion of wifi-tethering is back up and our old threads were locked in the undulge section i've decided to release this thread on how to browse on he internet explorer with wifi-tethering since metro pcs is filtering how we browse on their network. and this basically is the same concept as using chrome and firefox browsers by changing the user agent
and yes it can be done by registry or if ur lazy like me by using a browser add on called user agent picker, which has some neat preloaded user agent tags already in it to choose from or you can type your own.
Ok first thing first download user agent picker free from this link:
then once its installed open ur browser go to tools then toolbars then customize and u should see UA in blue on the right side select it and click move up till u see it on ur browser top right corner. now click UA icon on ur browser and erase what u see and copy & paste this into that box
Mozilla/5.0 (Linux; U; Android 2.2.1; en-us; SCH-R910 Build/FROYO)
click save changes and your good to go! to close that box after ur done making changes just press esc, to revert back to default browser tag just erase the user agent in the box and press save changes and it should be back to default. Anyways thanks to cafonez and TRS-80 For discussing these tags!
Their oringinal thread: http://androidforums.com/samsung-galaxy-indulge/454393-solution-wi-fi-tethering-issues.html
and yes it can be done by registry or if ur lazy like me by using a browser add on called user agent picker, which has some neat preloaded user agent tags already in it to choose from or you can type your own.Ok first thing first download user agent picker free from this link:
Code:
http://www.enhanceie.com/ietoys/uapick.asp
