using your hotspot free
trasher14
Hello im sure alot of you have seen this question can you use your hotspot for free somehow I looked it up and downloaded foxfi but does that let you use your hotspot for free without data charge and if no is there a way?
well according the play store app page for foxfi. it says that att has removed it from the market.
now keep in mind that you are treading a very fine line here at AF. trying to get free wifi is usually against your tos for att. but if you do get any of the tethering apps that are available for your phone then it will do as they say in the app description.
No app will allow you to have a hotspot with free data. Some apps will enable the hotspot feature but you will be using up your data on your plan, there is no way around this.
