Root Utilizing the partition HELP!
The_Billman
I have flashed the ROM and partitioned my SD card. Is there a step I am missing? After partitioning and flashing, it still only shows only 40 MB of internal space free. How do I utilize the extra partitioned memory?
[ROM]-[RLS2-7/21/2011]-KInGdOm ReWiND 3D-[2.3.3]-[Sense 3.0]
ok so this rom uses darktremor a2sd to move apps to your card. it is not automatic you need to type some commands to move your apps. so you have to download terminal emulator then:
type "su" and enter
type "a2sd install" and enter
it will reboot
next
type"su" and enter
type"a2sd datasd"
it will reboot again.
hope that helps.
