Root V 2.1 baseband and kernel & rooted
Hi ALL,
firmware - 2.1 update 1
baseband - 006
kernel - 2.6.29
build - 2.0.1.A.0.47
Does my above stat can use AOSP GingerBread (2.3.1) ?
Hi ALL,
baseband - 006
kernel - 2.6.29
Hi,
In order to enjoy Gingerbread 2.2.3 you need the following
A) Update and backup via xRecovery
Firmware: 2.1.1.A.0.6
Builld: 2.1.1
Need
Root + xRecovery
Busybox 1.1.7
Baseband - xxxxxxxx15
Cheers :)
Do or DO not... There is no Try - Yoda
Hi,
Builld: 2.1.1
Need
Root + xRecovery
Busybox 1.1.7
Cheers :)
but i already do some changes
baseband - 015
firmware - 21 - update 1
kernel - 2.6.29
Do this current stat is good for it or do u recommend other roms ?
sorry for my bad english >.<
Type : busybox uname -a into your terminal app and compare it with this :)
Linux localhost 2.6.29 #1 PREEMPT Fri Dec 17 18:35:45 2010 armv6l GNU/Linux
If you got the same thing you have the good firmware ;)
