Sorry if this has been asked but I couldn't find the answer after much searching. I just finally upgraded from MIKG 2.53 to 2.61. Once I did this I went back in to set up my V6 and the whole look changed. I tried running it the same way as I did when I had 2.53 but it did not work. I selected run as root then went in and found the v6 script but that is where it changed. There is no option to check for run as root. I pressed ok anyways, selected 0 thn 8 then 17 but then it just keeps prompting me to enter 0-17. Can anyone please help????
) has a lot more options.
