Root V6 script question...
DaRayvn
does anyone get theirs to say Hard to Kill??? i've done the process 3 times in a row and it just keeps saying Bulletproof.....
You're good to go. It's just an updated version of the script. I run this script every time I flash a ROM and it works awesome!! Enjoy!! :D
So after you run the script, what else do you have to do? I looked in my /data folder on my SD card and I don't see that it put a file there that I can choose to run on boot so that the script stays active.
I think it is persistent. When I have run it again, at a later date, I see that when it lists the before and after changes it made in memory, the readings are the same, ie, no change, so I think it it there without the script 'staying active'
The guide I followed actually said something about not setting it to boot. What you do is after a reboot, re-run the script. If the freemins or whatever are the same as the option you chose (or it says something obvious like "hard to kill") then you're good.
