Root Velocity .2 MetaMorph ImagePack
savoxis
Android Expert
Introducing the:
Velocity .2 Stock MetaMorph Template
Please direct all gratitude towards Trident for this Awesomazing Rom
MEDIAFIRE DOWNLOAD LINK
This package includes all the image files for ALL (yes all) of the applications packaged with Velocity. I have arranged these images in a fashion so you can easily use it as a MetaMorph template! You can also use this to reapply stock Velocity theme rather than restoring a Nandroid Backup!
Basic Instructions on using as a template:
Edit the png files to your liking with your favorite editor, it is important to keep the dimensions of the files intact.
Rename Velocity2.xml to your liking
Edit the first few lines of the Velocity2.xml file to add personalized information
ZIP up all of your folders and the xml file, rename this zip the same as the XML file!
Even More Awesomeness!
As stated you can also use this to test themes on your phone, since this will restore all the original PNG files to your apps and framework you can apply this to bring your phone back to Velocity .2 Stock Theme, no more having to waste 10-30 minutes and tonnes of space on your SDcard creating and restoring Nandroid Backups!
Before delving too deep into modifying the theme on your phone I do recommend making at least 1 backup just in case something does go wrong causing your phone to get stuck in a boot loop (this happens sometimes when creating custom PNGs if the dimensions are not exact)
Ill look into it when I get off work, I threw that all together pretty late last night, I might have missed something
Found a microusb cable here at the office so I was able to test this.
I reflashed Velocity .2, applied AlternateBlack, then applied The stock package.
It worked well, took awhile (34 apks modified) but didnt give me any errors, and when the phone came back up after the framework application it was back to stock velocity.
Has anyone else been having trouble with this?
By the stock package are you talking about the theme you uploaded here? I'm going to do some more testing.
I figured out what I did wrong, for some reason I had USB Debugging disabled.
