savoxis
Android Expert
Velocity Script
I have decided to keep a thread to track the Velocity Script, to make it easier to find updates, FAQs, and pull ideas from the community. Please post any issues you are having with the script, ideas you might have for new features, or any questons or comments you have.
The Velocity Script is included only in Versions of the ROM greater than 1.0 the script is incompatible with any other version of Velocity.
Script Features:
- OTA Update Capabilities for both Script and Velocity ROM
- Menu Driven
- Dynamic for Easy Updating
- Goodies are downloaded on demand to save space on your phone
- Boot Animation Changer
- System Font Changer
- Theme Changer
- LCD Density Adjustment
- CPU Information and Overclocking Tools
- FROYO A2SD Selector
- Ad Toggler
- ROM Odexing Script
- Disk Free Information
- Stagefright Toggler
- Keypress Sound Toggling
- Both Online and Offline Modes Available
- Manifest System to Control DLC
- Smart Zipalign Tool
- Dalvik2Cache Toggler
- RAM Freedom Script
- Boot Sound Toggling
- Boot Sounds Changer
- Downloaded Application Backup and Restore (Including A2SD {Thx Trident})
- Mirror System with 3 Servers
Script Usage:
- Open your terminal emulator or start ADB shell
- Gain SuperUser access by typing su then enter
- Type velocity and press enter
- The Script will Check for Updates at Launch
Backdoors:
To use these type velocity then the command (eg velocity -sd)
- -offline offline -ol ol
Starts in Offline Mode - -update update ud -ud
Starts the Script Updater - -force -forceupdate force forceupdate
Forces an update - -sdcard -sd sdcard sd sdinstall script2sd
Sets script download / workspace up as sdcard instead of cache, use this if you are out of space on cache. - adson|adsoff
Turns ads on and off, respectively - a2sdoff|a2sdon|a2sdauto
Sets a2sd default install location - bootsound on|off
Enable/Disable Bootsounds (1.1 Only) - dalvikvm X
Set Dalvik VM heapsize to X - clearcache
Clears cache and market cache - cleardalvik
Clears dalvik-cache - clearbatt
Clears Battery Status - stagefrighton|stagefrightoff
Turns stagefright off or on - sysapp X
Removes sysapp named X where X=App Name without .apk (eg YouTube)
