I was unsucessful in forcing the update by typing velocity fu.
Got scripts to open browser,thats cool!
Last nite my phone started acting very odd. Kept rebooting at random. I gotn it squared away and I thought it was really screwed by the way it was actin'! Anyhoo, I have the scribble boot anim. and I noticed at the end of scribble it does this cool lookin' sunburst type flashy deal, but it doesn't do it all the time. Is that normal? Does it mean anything I should be aware of? Also, how can I use different tones for different notifications? -----------"Rock on!"
For problems like reboots please post a logcat, without a logcat I cannot even begin to tell you where the problem is.
The sunburst only happens sometimes because your phone usually boots up before the animation is complete.
That is because recovery DID wipe your dalvik-cache. Since you have moved your dalvik over to /cache its new location is /cache/dalvik-cache, when recovery wipes cache is mounts the cache partition then deletes everything it can off of it.i wiped my cache in recovery and when i rebooted it took way long like the dalvik was wiped too.
Recovery did sucessfully wipe your cache, the reason cachemate showed that it cleared more after the phone booted is because there are parts of cache that cannot be wiped in recovery, because they are in use by recovery.But what i want to know is where did my cache go and why wouldnt it clear in recovery but did with cache mate?
I don't recall either, however it may be important to take note of what recovery you are using it is possible but not probable that ClockworkMod has a check to see if your dalvik is located on /cache and avoid wiping it if it is.Now this hasnt caused me any trouble just curious and dont recall (may not have noticed) this with dtapps2sd script for dalvik2cache!
I remeber in velocity .3 or .4 you could change clock color, i kinda miss that except with a way to remove it all together to.
Sorry about the lack of updates as of late I have been taking a sabbatical from coding.
I did want to get some work done but dont know what project to tackle, if anyone has any ideas let me know
And remember, almost anything is possible.
I would love to see lockscreen gestures incorporated into Velocity. You should also look at making LauncherPro or ADW the default launcher. They are far more customizable and based on a quadrant benchmark LauncherPro improves the speed of your phone. Lastly, it would be great if you could decrease the lag when switching back to the homescreen from a running application. In terms of the lag I would be more than happy to send you a logcat.
Do you have widgets moved to your sdcard that are in use on the launcher? That would cause some lag. Also is it only certain applications? I cannot seem to reproduce this, a logcat may be crucial.
As far as alt launchers, I do plan on having a tool in the script to remove launcher2 and put in adw as default, but for theming purposes I think we will keep launcher2 as the one that ships with the rom
Oh, and I have noticed that it happens with most applications, but only if I use them for an extended period of time.So how bout that velocity script guys? Haha
How/where do I send logcat?
Has anyone noticed that in portrait, it's gingerbread dock, but in landscape its froyo
Yeah its I just noticed its still like that in the beta, thanks for pointing it out!
