dautley
Android Expert
If you want the LG screen back you can flash "LG BootSplash" located at the bottom of Death2All's Frunisher ROM post http://androidforums.com/death2all1...cked-fast-stable-themed-updated-4-4-11-a.html
Flashing the splashes is far from perfect, the images corrupt easilly and flashes fail, but a failed flash just causes a blue screen, to fix this just reflash, clear your downloaded cache if it fails again.
EDIT: I think I found a fix Im gunna test some more probably release a v27 later
EDIT: Updated to v27, fixed the splashes I believe (I just have it flash it 2 times, could still mess up if the download gets corrupted) and among a few other things, I implemented a help system, press h in any menu for a simple, brief desc.
You weren't by chance trying out the way to disable keys on the Ally keyboard we had discussed in another thread, were you ? That could have an effect on keys not working.
I suppose one route to take would be to go back and re-flash Velocity again and then work forward from there.
Is there a way to go back to script 27?
Actually I have several Nandroid backups. I make them periodically, and also make complete SD card backups to my PC weekly since having my SD card die on me twice with this phone.
What I didn't know is that restoring a Nandroid also restores Velocity Scripts.Thanks! I'll go that route later tonight.
I hadn't thought of this option, so either way it's worth a shot. The worst that will happen is putting me back a week or so in time. And possibly getting stuck at 600 MHz if it doesn't work. Let's hope it does.
Edit - I am restoring my most recent Nandroid, which I made on 4/11/2011 prior to implementing the "move Dalvik Cache to SD" which was recently provided in (I think) script 26. That function gained me tons of internal memory (like increased from 27 to 207 MB). I did not encounter any problems with the several apps I have installed after moving the Dalvik Cache. Not sure if that would have any bearing on this issue with Script 28 though.
After restoring the Nandroid just now, I rebooted and opened Terminal. I had previously added the Terminal option to run SU and Velocity when Terminal starts. I removed that option today when Script 28 malfunctioned, to see if entering it manually would help (it did not).
So, I am now in Velocity Script and seeing the question asking me if I want to download Script 28 again. It appears restoring the Nandroid does in fact restore back to the previous script as well.I replied "N" to the update. The screen then revealed I am in Script number 26. So I will have to stay here until I get word that Script 28 or newer is safe to use.
I am re-running the move of Dalvik Cache to the SD card (after it told me to clear my Download Cache to make room for the operation). One thing that I find a bit unsettling is that during this move of the Dalvik Cache, the Terminal screen says it is moving the cache and then "phone will reboot to complete the operation", but then it just sits there appearing to do nothing for several seconds. If it said "will reboot shortly" or something that would help me know it has not frozen in mid-operation, which I usually suspect when I don't see anything happening.
OK, I am back with 180MB free internal memory and running OC'd at 768 MHz.
Thanks for suggesting the Nandroid restoration. I'll continue to monitor this thread for news that Script 28 has been fixed.
Sorry guys, my brain hurts, I have been hard at this for about 4 hours now.
And the results are in, fix is up with v29 but if the v28 messed up your wget you will need to flash this script patcher i made in recovery, which will fix your wget and update you to v29.
The new v29 uses awesome md5 checksum technology to ensure you are not screwed by evil corruption demons, after mastering this new technology I can now incorporate it into everything making for no more hasstles.
Also in v29 I have recoded the first bit of it, hopefully debugging the connection checker, I thoughly tested myself, but crazy things happen.
Ok, uploading now
Ok, its up, gnight
