Root verification failed
cb3p0
Member
wheni try to install velocity v.3 i get an error that says verification process failed, and that i have a corrupt ringtone in E:/system/media/ringtones. someone please help me
Or you could have the old recovery that has a bugged verification feature, so check out the updated recovery.
i agree with vmanisme its not a bad dl just got to use the new recovery. it might be your sd card too so try to format it then use the new recovery to flash your rom.
Depending on which recovery you are using you can toggle verification on and off. In the drellisdee recovery just go to other and select toggle sig-verification. Im not sure if u can do this with clockwork?
nice to drop some knowledge on us lol. verification it is off by default... -sigh-
