[Verizon] Anyone removed bloatware using Titanium backup?
Hello everyone,
I was wondering if anyone had put together a list of bloatware that comes on he Verizon SGN in the USA and if these things can be removed? I don't want to change the basic functionality of my phone but want to remove stuff that is just taking up space.
Thanks
-S
there really isnt bloatware, and if your installing roms, they remove the 2 vzw apps that are on the device, also, if you long press the app in the drawer then when it goes to home screen, move it to Info and you can disable it there.
also moving this to All Things Root
Thanks so much for the help. I guess you kill two birds with one stone. Thank you for moving it to the all thing's root sub folder.
-S
What's bloat to some is not to others. I personally don't use Gmail, Google+, Talk, or many of the other preinstalled Google apps. Just saying.
Not so much an issue on our phone but it's never a bad idea to freeze any apps you are unsure about. If it doesn't cause any functionality problems, you can go back later and give them the axe.
The vzw apps won't be in that category though. Feel free to give them the death star blast.
