Root [Verizon] app2sdnote2.bin failed: device or recource busy
I am having problems with my rooted Note 2 N7100. Every has been running fine. A couple of months ago I formatted the 64g SD card as recommended with the device and everything had been running perfectly on there. I also used the app2sdnote2.bin script to share the internal space and again everything was good.
A couple of days ago I took the extcard out to put into my mac to copy some data across, though the system did not recognize it. When I put it back into my phone and restarted it, I can see the drive, though I realized then that when installing things that they go onto the intcard, which was then saying that there is insufficient space, so have uninstalled some things which works, though this should not be happening. I went back into applying the app2sdnote2.bin tweak, though get this error on the install:
exec /system/bin/sh '/storage/sdcard0/Download/app2sdNote2.bin'
h '/storage/sdcard0/Download/app2sdNote2.bin' <
mount: mounting /dev/block/vold/179:17 on /mnt/sdcard failed: Device or resource busy
/dev/block/vold/179:17 on /storage/sdcard0 type exfat (rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=cp437,iocharset=utf8,namecase=0,errors=remount-ro)
/dev/block/vold/179:17 on /storage/extSdCard type exfat (rw,nosuid,nodev,noexec,noatime,nodiratime,fmask=0000,dmask=0000,allow_utime=0022,codepage=cp437,iocharset=utf8,namecase=0,errors=remount-ro)
I can see in Storage that it is connected, though get the error still.
So, what is going on here, and why would this be taking place?
I have therefore backdated the system to a few days ago to when it was working, and still the same problem
Any ideas how to fix this sharing to how it was?
Hey jouleskeys, welcome to the AndroidForums!
I've moved your thread over to the Samsung Galaxy Note 2 VZW all-things-root area (let me know if VZW is not your carrier--didn't realize there were so many for this device :eek:).
Hopefully the good folks here will be able to help you out.
Cheers and best of luck!
