John_Roger
The phone has not even been activated. Should I wait for the OTA or flash Jelly Bean. I've not messed Round with root since my Droid X. Should this be a piece of cake being that I'm not worried about losing anything?
The Jelly Belly ROM is fantastic, very stable. Plus the search function has not been disabled, as it most likely will be on the official JB OTA. This may mean a significant loss in function of perhaps the best part of JB, the updated voice search and Google Now. So if you are willing, I say flash away. Plus since the phone is new, you can unlock the bootloader, and not have to worry about the fact that it wipes the sd card partition.![]()
Probably the easiest is Wug's Toolkit, found here:
Wug's Galaxy Nexus Root Toolkit
If you want to get into the nuts and bolts, you can follow this step by step here:
http://androidforums.com/verizon-ga...gs-root-samsung-galaxy-nexus.html#post3736589
