I rooted my Gnex a week ago and flashed the latest Liquid rom. I made a few backups (a clean one as soon as I rooted, a clean liquid rom, and a customized one right before I began messing with it again) and then decided to check out CM9 nightly. I noticed that I would get an error when trying to install / restore through Rom Manager. It would take me to the clockwork recovery and mention the error, so I just took care of it manually. No big deal. After checking out CM9, I went to restore one of my previous backups and got an "MD5 Mismatch" error (or something like that, cannot remember and cannot recreate now) and it would not restore. This was the case with all of my backups, including my clean stock backup. I tried to install the Liquid Rom fresh from my "SD card". It seemed to install just fine (yes, I wiped both caches, battery stats, data, and fixed permissions first), but I ended up frozen on the "Google" boot screen. Now I am at a loss. First of all, I don't know how to get back to the clockwork recovery (thought it was volume down + power, but that takes me to the fastboot screen). How can I get this working again? I'm not opposed to reseting the entire process since I was having some problems with clockwork recovery prior to this. I used Wug's root tool.
Thanks!
Thanks!
