I've been lurking for quite some time and haven't been able to find a solution for my issue. Here's what happened:
I cracked the screen on my Galaxy Nexus and got an insurance replacement. I then used ClockworkMod Recovery to copy over from my old device to my new device. All was good for about 12 hours when the new device started boot looping with the flashy color animation screen. I figured that might have been something I did, so I tried doing a factory reset and the like with ClockworkMod Recovery and managed to totally mess the phone. After trying to do a factory reset, the phone wouldn't boot up at all anymore -- I just get the dreaded red triangle with exclamation point. I tried formatting all the partitions with ClockworkMod (which was a bad idea). Ever since then, I've been stuck. I've spent several days so far trying to get this thing working. I have to note that Odin and fastboot modes work perfectly fine.
Among things I've tried unsuccessfully:
Flash to stock using Odin
--Odin says everything is fine, when I flash with a stock ROM that I downloaded. Upon reboot, nothing is any better and I still get the red triangle/exclamation point.
--When I try to use the tar files that ClockworkMod generated, Odin crashes immediately.
Push custom ROMs to /sdcard/ using adb while booted into ClockworkMod in hopes of getting the system to boot.
--This never works successfully. Sometimes I get no error but can't find the zip file. Other times I'll get an I/O error, or even a read-only error. The original backup is giving me checksum errors.
Flash factory ROMs using fastboot.
--I always get the red triangle/exclamation point.
Restore and flash with WUG's toolkit.
--Same thing as when I try to use fastboot. It seems that flashing the device goes fine, but the device will still not boot.
After every time I've flashed the device, whether using Odin or fastboot, I've tried doing a factory reset by pressing power+vol up+vol down and then selecting factory reset. This hasn't made any difference.
I'm about to give up on it and send the device back to the nameless insurance company, but I would like to lock the bootloader first. I can't even seem to lock the bootloader! In fastboot, I type the usual 'fastboot oem lock', and the device reports that it is locked, but after rebooting, the device always reverts back to having an unlocked bootloader.
Have I missed anything? Any thoughts? For now, I'm using my old device with the cracked screen, but I'm running out of time before insurance starts screaming at me to send back my old device. I'm lost.
