[Verizon] Confirmation when using "Wipe data/Factory Reset" in CWR?
Maul
Sorry for the newb question. Getting ready to flash AOKP M3 and got to the part where you run the above option. I'm running CWR 5.5.0.4. When I select the option, it just sits on the black hat CWR logo. I can hit the power button and get back to the menu, but nothing seems to work. Even Reboot System does nothing. Are you supposed to get a confirmation that the wipe is complete? Should I battery pull or just go ahead and try flashing AOKP?
Thanks in advance!
I think you toggled the "Back menu button" try pressing volume up and down at the same time to see if you can get it to say "Back menu button enabled" then try again
Yep, that was it. I tried hitting and holding the volume and power buttons in various fashions with no luck. Finally just kept scrolling up and down and it re-enabled. Then was able to do the wipe. AOKP is booting up now! :D
Thanks a lot for the quick response!
No problem bud. I still can't figure out why the option to toggle that off is even available :confused: welcome to posting on AF its all downhill from this :D;)
dear god yes, that overscroll problem was the most annoying thing in the world, its what also causes the back button to become disabled!
i think the touch version is hands down best cwr koush has developed
I installed it from Rom Manager and that's what it gave me. The touch one made me nervous when it said it may cause issues with some ROM's. I may look into getting the 5.8.0.2 though...
Thanks again!
it doesnt cause issues maul, that i can promise you. i have installed all these roms, and i have had the touch version for quite some time
and still no issues with that
I'm actually still using the "unofficial" touch CWM because I like the setup of it better than the way the official one is laid out. :-/
However, either one is miles better than the overscrolling that just about drove me crazy with the regular one.
