jrock204657
So I've been having problems for a while now and don't know what the problem is. I'm rooted running CNA (newest release) and it's done it with other roms as well..but anyways I will just simply turn my phone off and on just to reboot and I'd say about every 1 out of 6 times it gets stuck at the Google logo. So I pull battery and try to reboot and same thing. I then try to restore a nandroid that I had made (which I have plenty) and I always get an error saying there was an error restoring data. So I can't restore a backup so I end up just wiping and flashing the same rom and it takes forever to boot up but it finally does...I have no idea what the hell the problem is if anyone can help me it would be MUCH APPRECIATED!
Also, I just recently swapped out my old GNexus for a brand new one about a month ago so this ones pretty "fresh".
Thanks in advance,
Justin
Thanks in advance,
Justin
