Verizon Tabs have that function blocked since they dont want you using them for making calls. I have been in contact with a Rom and Kernel developer to find a way to enable that feature on VZW tabs for that exact purpose, skype and G-voice calls.So you will have to ad some 3rd party rom/kernel to get that function.
Im rooted but I dont know what app to look for. I replaced the wpa_supplicant file to get ad-hoc working on wifi (tether from eris). Now, if only BT would work.
It may be because your headset doesn't support a2dp. That would explain why BT earphones work ok. There are BT headsets (Jawbone for instance) that support a2dp so you can listen to music etc through it.
