* I think
if you are in that screen you should be able to use your vol buttons up or down to choose recovery, then hit power.
once in recovery you should be able to use it as normal, flash zip from sd card, choose zip, choose yes, etc.
if you can't access CWM recovery you may not have installed it right, try again from rom manager.
