When going from 1.6.1 back to 1.5 do I need to do anything besides wiping cache and dalvik cache?
Updated
1.2.0 through 1.5.0 have been great, noticed odd battery drain issues on 1.6.0 and 1.6.1.
1.6.4 is better, but not as good as 1.5.0 and below
So is the general consensus that 1.5 or lower are IMOs beat for AOKP??
Battery has been bad for me today. But just flashed the aokp rom and 1.6.4 today. Should I give it a few days or flash a different rom and kernel?
I'm using this and it seems great, but I don't really have anything to compare it against. I've heard good things about franco's. Anybody have a good comparison between the two?
Tried the update today and ended up loading my backup. Had problems with it not drawing my home screens and seemed to have lag issues. I made zero changes to the kernal other than loading it.
I'd give it 2 full days yeahI
Will do. I think I will flash 1.6.6 tonight when I get home and see how I roll. Just have to remember to wipe dalvik cache lol.
I will run this ROM for a few days, but I really want to try P3Droid's ROM. It looks sick especially with his pull down toggles and bigndad's themes!
Thanks again for your help bro.
There is a lot of good stuff coming out for sure! Anytime![]()
Hey man. What ROM are you running at the moment? AOKP I presume?![]()
Yup 17
Sweet same here. Now if I can just get the kernel loaded tonight. Hope battery life is better. Twas bad yesterday. 7 hours or so moderate use and twas dead. Standard battery. I have an extended on order from VZW coming this week.![]()
haven't needed to try it yet as battery life has never been an issue for me. Nice to have it though for those days I know I might need it!Thanks for your feedback man. Well I flashed 1.6.6 here at work a lil while ago. Dunno if its a coincidence or not, but my phone seems to be getting warm/hot since I flashed it. Will keep an eye on it the rest of the day to see how it goes.
If it continues, will flash an older kernel or maybe just try out P3's rom. I hear its pretty darn good.
Thanks!
We have 2 Imo threads now. Perhaps they can be combined? Anyway, 1.6.6 exp 2 is running awesome for me. IX governor 230 slot. No issues with this kernel, I think he finally nailed it.
I have lean kernel 1.6.6 exp4 230 but what do you guys mean when you say 230 slot? Is that in the undervolting page in setcpu? and you just click it ? or do you mean set the low cpu to 230 and reboot?
Set the speed to 230MHz (underclock the cpu). You'll notice if you open up setCPU you have the option to lower the cpu frequency to 230MHz with the 230 exp4 1.6.6 version. I'm trying it now and also using the hotplug gov. I'm keeping the max at 1200MHz
ok,
but I thought InteractiveX already enables the hotplug needed for screen off cpu off
