Trooper
Android Expert
I thought that too. They're learning me over @ the rootz
Hotplug governor can and will disable a cpu core when the the screen is ON or OFF depending on the load. InteractiveX is a hybrid of sorts and has a screen-OFF hotplug feature that disables a cpu core ONLY when the screen is off. From what I understand they also scale differently when the OS is calling for more power to run a certain task/tasks. It's all very fascinating to me
So we need to run the hotplug goverenor and not interactivex on setcpu?
/me is confused.
Ok I am running the LeanKernel 1.6.6 on Redemption ROM 1.0.4.
In SetCPU, thanks to binaryvisions, this is all I did.
Open up SetCPU.
Click on Scaling and selected interactivex
Click on Set on Boot.
So, is this all I need to do? Is there something else that needs to be done to "save" this config in SetCPU?
Now I see some of you talking about the hotplug governor setting.
You can see my confusion.
Again, not a n00b here, but can someone dumb this all down for me a bit?
Thanks!
it's sickening how fast stuff just pops out. In a good way!
