[Verizon] [KERNEL][4.0.4] LeanKernel 3.10.0 (7/2)
Still getting great battery life with 1.6.6 exp3. Curious as to how 1.7.3 will be on the battery.
Hope to see some reports soon!
How's 1.7.3? I'm going to flash AOKP build 20 today (looking forward to the lock screen changes!) and 1.7.3. Hope all goes well.
Try something for giggles. Turn auto-brightness off (set it to a static level to your liking) and see if you can reproduce that same lockscreen lag you speak of.
Yeah, that seemed to have fixed it. I like keeping auto-brightness enabled though. That wasn't an issue stock, so I wonder why it is on a custom ROM/kernel?
Just flashed 1.7.3 though which supposed fixed it. Seems good so far too, but it's only been 30 mins.
I agree I love the auto-brightness and use it 24/7.
I saw that 1.7.3 addressed some lockscreen lag let us know after you've been with it for a full day how its doing.
It seems there's still lag upon unlocking with auto-brightness enabled on 1.7.3 (InteractiveX governor) :(. Disabled auto-brightness again and it unlocks silky smooth again. It may be a tad better now, but it's still definitely noticeable.
Also, I haven't really noticed much difference at all in these kernel revisions from 1.6+ (when I started using LeanKernel) in terms of battery life or performance, lol. I'm not sure why I keep updating it, I guess because it's too easy/fast to do, so I might as well.
It seems there's still lag upon unlocking with auto-brightness enabled on 1.7.3 (InteractiveX governor) :(..
Curious and runnin AKOP20 and 1.7.3 I did the InteractiveX & auto brightness thing, let it go to sleep several times, no lag. Rebooted, made sure the auto and interactiveX was going on, no lockscreen lag.
You may need to reflash it all, I dunno and have not read all your posts.
Just Sayin.
I just flashed AOKP build 20 with 1.7.3 today. Too early to say, but so far so good.
Help ole T4rd out and duplicate his settings and see if you get lockscreen lag when you open the lockscreen eh?
InteractiveX governor and auto brightness.
Had auto brightness on already. Turned on InteractiveX and no lag. Rebooted, and still no lag.
You know you guys can just post it up as an attachment to the post, right?
After reading and reading about what the "best" kernel is, I decided to try out lean. I hear good and bad about all the kernels, so I just picked one and jumped in. I don't remember what I was getting with stock, but the results aren't bad, at least.
My "screen on" time, was a little over 3 hours, I don't remember exactly.
If I wanted to flash the stock nexus kernel, is there somewhere I can get that? I probably should have thought about it sooner, but oh well. I wouldn't mind running lean for a couple more days, and then flash back to the stock kernel and see how it does by comparison.
After reading and reading about what the "best" kernel is, I just picked one and jumped in.
Nice numbers.
C'mon fella! Go to settings and about phone and give us the kernel your using.:eek:
Heh! Just picked one at random! :eek: Thats not how we roll bro. You know we gots to know.
Funny. :)
Your stock Kernel is in the nandroid back up you are supposed to make before "Just Diving In". Ha!
You just flash back eh? Change your ID to Brave Heart? William Wallace? :-)
You can get the stock kernel back by re-flashing the ROM AOKP as that is what is included by Roman. Just wipe cache partition and dalvik cache and re-flash.
You could also get the stock kernel for 4.0.3 here or the stock for 4.0.2 here. These are both from faux at rootzwiki.
Nice numbers.
Funny. :)
Well, I thought I had flashed lean1.7.4, but it was actually 1.7.3... not sure how much of a difference there is.
On that battery charge, I spent about a hour in the 1.2ghz range. Would it help battery life if I went into setcpu and dropped the max speed? So that hour spent at 1.2ghz was now clocking at 1ghz or 900mhz?
here's a few more screencaps, while running lean1.7.3. I ran Quadrant on the stock kernel, with lean and then with lean capping the speed at 920mhz.
stock kernel
lean1.7.3 kernel @920mhz
lean1.7.3 kernel @1.2hgz
