The real test, in my opinion, is the "screen on" battery drain.
I agree, all of that for under 1% an hour is damn good, but how is it treating you when your screen is on?
You will never see a difference in screen on battery drain from one kernel to the next. The screen is by far the biggest power drain on the phone and kernels do not change how much current is drawn to power the screen. Now, there may be a difference in screen on time if you run different governors regarding how it ramps up to max frequency, what the max frequency is, and what the voltage is at that frequency, but that has nothing to do with the screen.
Ideally, the best way to test kernel battery life would be to keep the cpu at a relatively high frequency and keep it from going to sleep with the screen off and compare results. Maybe set the min frequency to 700 and play stored music on a continuous loop to keep the processor awake at the lowest volume setting so the speaker won't affect your current draw. All that with screen off of course. That will give you an idea of the difference from kernel to kernel with the screen not having any affect. 20-30 minutes of screen on time difference and variances in ambient lighting conditions will make a huge difference in results when comparing from one kernel to the next.
Leankernel v2.0.0 is posted. Change log here.
v2.0.0 doesn't seem ready for prime time, IMO. Dev didn't test it at all with LV on any freq slot and there's people reporting issues of weak haptic feedback (mostly fixed with reboot), no sound and random reboots. I myself couldn't get any sound to work, even after changing all voltages back to stock and changing the governor.
Thx for the feedback. I give new kernel releases a day out in the masses to see exactly the kinds of things you stated.
No prob. Some people are reporting things working fine after a reboot, but I rebooted 3 times after upping the voltages to stock and couldn't get sound to work. I have had 0 issues with all previous versions of Leankernel (started using them at around v1.4.0 I believe). You shouldn't have to reboot to fix issues after installing a kernel. That would lead me to believe that the issue could re-surface at any time under normal usage.
Just posting my experience as that's what forums are for, eh?![]()
Mercy! I loaded 2.0.0 last night, it seemed very responsive and smooth. I did have to re-boot to get the haptic feedback back to normal and again just for good measure.
On interactivex, 1200/350, 2100mAh battery.
I put it down at 1:30 AM @ 41%.
Picked it up @ 7:28am @ 40% !!!
1% in 6hrs?
It's been updated to 2.0.1 to fix some of the previously mentioned issues. Running fine on stock 4.0.4 ROM and radios. Will give it a few days to settle.
I had flashed 2.0.0 and the only issue I had with it was when my alarm went off this morning the dismiss/snooze pop up was missing so I couldn't stop the alarm. Had to pull the battery. The wife was less than pleased. LOL.
Lean 2.0.0 is working great for me. Was at 60% after 13 hours.
