Is there any way to update to 4.4.4, and change it to a google play edition?Last I heard, Stump Root was working on vzw. May require using the brute force option provided in the app, not sure.
[Root] Stump Root for LG Devices (2012 - 201… | LG G3 | XDA Forums
For Verizon? No. not yet anywayis there a way to unlock the bootloader?
then how can you root?
Thanks, but what about when LG G3 gets the android 4.4.4, will they fix this to where it will work with that version?
Well how do you unroot?Not that I've heard of. General consensus is the 11c modem does seem to run a bit better, so worth installing, even if you don't want to bother with boot or system.
My phone is urooted but what I am trying to do is set the phone back to like when I first bought it like a factory reset, but I tried a factory reset and all the things I deleted like the apps are still gone, so I need a ROM of 4.4.2.What exactly are you trying to do? Unroot?
In that previous post, you stated you were rooted, thenSo there is no Verizon ROM for 4.4.4? My phone keeps asking me to update, but I don't want to lose root. And can I unroot with stumproot?
you performed a factory reset, and are now unrooted?My phone is urooted but what I am trying to do is set the phone back to like when I first bought it like a factory reset, but I tried a factory reset and all the things I deleted like the apps are still gone, so I need a ROM of 4.4.2.
Yes just a factory reset.In that previous post, you stated you were rooted, then
Is that all you did---a factory reset?
