quickmustang
Solved! Delete .android_secure from your internal memory if you are having the same problem!
With every back up I make with Rom Manager, when I attempt to restore it, I get an error message. It says:
Checking MD5 sums...
MD5 mismatch.
When I go to show log, it says:
md5sum: nandroid.md5: No such file or directory
MD5 mismatch.
Any idea what could be happening? If I rebuild the MD5 sum through ADB with this code:
adb shell
# cd /sdcard/clockworkmod/backup/2010-06-29.20.22.53
# rm nandroid.md5
# md5sum *img > nandroid.md5
Then everything works again. Any ideas on why it won't build the MD5 sum correctly to begin with? How can I fix this?
MD5 mismatch.
MD5 mismatch.
adb shell
# rm nandroid.md5
) I would offer to come and help in person (not that that would necessary achieve much). Hope you solve this...it would be a shame to switch phones for such a stupid problem.
