Anybody done this and noticed anything different? Im doing this on a galaxy nexus and i read on other sites you do it at a full charge than let it go completely dead than recharge and thats how you set it. Is this still the same as i was using instructions for a older HTC phone.
Dianne Hackborn said:Today's myth debunking:
"The battery indicator in the status/notification bar is a reflection of the batterystats.bin file in the data/system/ directory."
No, it does not.
This file is used to maintain, across reboots, low-level data about the kinds of operations the device and your apps are doing between battery changes. That is, it is solely used to compute the blame for battery usage shown in the "Battery Use" UI in settings.
That is, it has deeply significant things like "app X held a wake lock for 2 minutes" and "the screen was on at 60% brightness for 10 minutes."
It has no impact on the current battery level shown to you.
It has no impact on your battery life.
Deleting it is not going to do anything to make your more device more fantastic and wonderful... well, unless you have some deep hatred for seeing anything shown in the battery usage UI. And anyway, it is reset every time you unplug from power with a relatively full charge (thus why the battery usage UI data resets at that point), so this would be a much easier way to make it go away.
What I don't understand is how battery life shoots to 60% so fast.. than goes down about half the speed to 20%.. than 20% takes forever to go down from there
