Root Verizon OTA Flash Update
silent42
The Verizon Flash Update keeps trying to install on my Bugless Beast .4 phone. When I click "install" it reboots the phone, and tries to install but fails on the install and goes straight to Clockwork Recovery Mode. Then a couple days later it tells me to install the update again.
Does anybody know of a way to disable the update notification or successfully install the update so that it will stop bothering me?
Thanks for any help.
Even with the above fix applied to my phone I was still getting the flash update notification. I finally just had to change to another ROM. I am now running UD8 without any notifications. I do hope Peter puts out a BB v.5 because I really do like his ROM.
sorry I thought pete had updated this to fix it with FRG22D. I can make an update.zip that will fix it although someone will have to be a guinea pig since I dont have a D1 anymore. Its just a build.prop edit so there is no real risk flashing it
