[Verizon] Radios - where are we?
skiflyer
I recently flashed all over the place to play with JB. I was doing JellyBelly and Vicious, and back to ICS and blah blah blah.
I'm at a point right now where I need the stability, so I went back to my old favorite - LiquidSmooth... 1.5MR1. Everything is great, but I'm noticing lots of lag in my radio connections that I didn't notice previous to all the JB flashing.
I've also moved and am in a lot more cinder block basements recently - so it could just be the environment. But I figured I'd do a sanity check with you folks, what radios should an ICS user be on now? I'm on I515.09 V.FC04 / I515.FC05 and have just never been very clear about which flashes touch my radios and which do not.
Thanks!
I am using the same radio as the OP, but I'm having some issues and wondering if folks have had better luck with older radios in regard to call quality. I will die a little inside if I have to give up this phone :s:
lol. I've tried them all and the newest ones have the best reception for me. They are all in flashable form so I think the best thing to do is to try them all out giving them each a couple of days and see which one works best for you and your uses. I have linked them in the jelly belly thread under "misc"
+1 for this.
The older E-series radios gave me -95dbm reception in my dining room. The new F-series gave me -83 dbm in the exact same spot. That's a HECK of an improvement!
