AOSP Bugless Beast 4.1.1!
An AOSP nearly stock ROM along with Jelly Bean Bootloader.
Change log
Download
Twitter feed
An AOSP nearly stock ROM along with Jelly Bean Bootloader. Change log
Download
Twitter feed
) by downloading the apk and placing it in your system/app folder.Cool, used to love Pete's work on the D1.
Will try this on the nexus tonight. Any instructions on how to flash it?
I'm pretty sure Google made chrome the default browser for JB
Not yet, the server for Bugless just quit.
I was getting the same behavior. I went into the Google Now settings, then Voice, then "Download offline speech recognition" and once that was installed, things worked a lot better. Try that see if it helps you too.Im having an issue with google now, the microphones are being EXTREMELY sensitive, and it isnt delivering search results.
I'm running it now. Just finished getting it set up again with all my crap on there. Runs very smooth, everything loads quickly and it's stable. Haven't had time yet to play with all the new features, but I did find that you have to manually install Adobe Flash via APK rather than through the market. It does work once installed though.
I did have to wipe my phone to get it installed. I was running full stock, and tried to just flash it without wiping and it did flash, however it wouldn't boot. I let it sit at the startup animation for 15 minutes. THen I went back, wiped phone, cleared caches and then flashed again and it worked fine.
Thanks!
